Following on from the "when can we expect the next generation of consoles" thread.
I thought it would be a good idea for us to post what we want our next gen consoles to offer us
What I would like in a Next Gen console?
A decent amount of ram, 1GB would do nicely.
If Hard Drives are the future of consoles, at least use 7200rpm models... or better yet, lets move to Solid State Drives.
Both of these should speed loading times, which are still lagging behind PC's.
Gigabit LAN and Wireless N capabilities.
Generally they should be smaller than current Gen - the Wii may be too small for some of the features they'd pack... but personally the 360 and the PS3 are on the large side.
Silence.... I can't emphasize that enough. Good quality, quite/silent fans that push a lot of CFM don't exactly cost an arm and a leg. And put in a quiet optical drive for goodness sake.
Slot-Loading Drives... they're wonderful inventions, and it's annoying they're not easy to get hold of for PC's
A stable frame-rate and at the minimum games should be putting out 720p
A way of not having to put of with the 10 year old kids that think they're awesome at a game, you beat them and then put up with abuse for it.... heck I'd like a way of not having to play them at all personally.
Backwards compatibillity with this generation of consoles as standard, regardless of what version of a console you buy or whether your in Europe or the US.
Finally... a sensible price for the console and all peripherals.
Now I don't mind paying extra for something if it's worth it, but I don't expect to pay close to £100 more just for a larger HDD... when if I bought a regular HDD from an etailer like OcUK it would cost me £25.
£30-£40 for controllers is also ridiculous.
Feel free to add post yours, or shoot mine down![]()
NokkonWud said:Sony to care about us in every way instead of treating us, and America to a lesser extent, like ****.
Not the same Tunney. Nintendo are bad, but Sony take it to extremes.
The developers of said hardware work along-side the developer, fine. Opening it up to all peripherals paves the way to people getting mice and keyboards working.
I'm also against full installation of games.
I'm also against 1080p with full AA and AF, the impact on the system is huge much more than people think. Get it at 720p with AA and AF on all systems and a consistent frame-rate is MUCH more important. We've just leaped into HD, leaping into FullHD already would be incredibly foolish.
- 1 control pad design with built-in rechargeable battery and charging lead. Good triggers and a good D-Pad
Why would you want the battery to be built in? The 360's method of letting you choose between swappable battery packs, either official or with regular batteries, is surely a better idea?![]()
I do think by the time those consoles are out the gpu they will have for them will easy do 1080p at 60fps with loads of aa and af, going on what out for the pc now like the 4850 and 9800( never mind the 280/4870),never mind what will be out in 12 to 18 months.
They need to add quite a lot of ram and not cut corners to much.
.The only thing Sony have really done positive is give online gaming for free.
I've always seen as a negative.You can have small or powerful, not both with reliability.
Seen how cheap Xbox 360 games are in Japan/Korea?
Depends how you look at itI've always seen as a negative.
