Motherboard for Q6600 - anything new out there?
5 Apr 2006
I'll be upgrading from a 7900GT to a 4870 GPU shortly, and though I'd upgrade the CPU to a Q6600 while I'm at it. I know the Nehalem range is out in the not too distant future, but this will be very expensive for a good while and I'll upgrade in 1-2 years from now.
Is there anything new on the motherboard front for the Q6600, or is the Asus P5K or Abit IP35 still the way to go? They seem a little 'old' now. I'll be overclocking the CPU to 3.2-3.6GHz. Also, are these two motherboards PCI Express 2.0 compliant? I cannot find out in the specs or on the manufacturers pages, but it would aid the 4870.
Thanks!
You can't go wrong with a P45 Chipset mobo.
Full PCI-e 2.0 support, crossfire 8x8 and the best for overclocking.
An Asus P5Q mobo would be great for your needs.
Deluxe
P5Q-E
Both have 16Phase power and offer superb clocking.
You also have the option of sticking another 4870 in down the line to.
Cant recommend the P5Q Deluxe enough - currently using with a OC'd Q6600 and its very stable. The board makes overclocking really easy - i have left almost all voltages on their lowest settings and havent needed to fiddle with them yet!
[Perhaps a slight aside, but i have found the ASUS express gate thing really useful - it does get online very quickly]
Deluxe
P5Q-E
You also have the option of sticking anothee 4870 in down the line to.
But at 8x / 8x only on P45 ? X38 or x48 for 16x / 16x PCI-e 2.0 goodness ?
Yup, only 8x/8x on a P45
" We find ourselves with two physical PCI Express 2.0 16x connectors for graphics boards. These can either be configured as a single sixteen lane slot (with the secondary slot disabled), or for multi-GPU configurations as two eight lane slots. Considering that every lane of a PCI Express 2.0 slot has double the bandwidth of a PCI Express 1.1 slot, this should be ample for almost any real-world situation. "
The 4870's/280's seem to be benefiting quite nicely from 16x/16x configs when in SLI/CF
Don't get hung up on the 16x 16 xfire.
It seems current cards do not take a hit.
And with the P45 being such a superb clocker I would get a P45 over an x38 if buying a single card solution setup.
easy rider what would you recomend for a dual card setup x38 or x48 considering asus maximus formula or the asus rampage (both ddr2)?
Depending on budget, and going for a dual card setup from the off I would get a Asus Rampage Formula Intel X48 (Socket 775) PCI-Express DDR2 Motherboard.
For a single card with the option of xfire open
P5Q deluxe.
Deluxe
P5Q-E
Hate to be picky, but the P5Q-E has 8 phase power :p
But from what I've read so far, doesn't seem to make much difference. I built a system for a friend using the P5Q and it had rock steady volts under Orthos.
how come no one recommend the Gigabyte GA-EP45-DS3? very reasonable price, full features with P45 chipset. is it a crap clocker or something?:p
Deluxe
P5Q-E
Thanks for the suggestion, been reading about the P5Q Deluxe and it seems like a great solution for me - the price is not too bad either. Online reviews are excellent, well, once the latest BIOS version is applied that is. And since I will only be using a single card GPU solution the one PCI-E 2.0 lane with 16x will do just fine.
Any idea if this board would have issues with aftermarket coolers? It looks tight with all those heatpipes, and I will be wanting to use a Thermalright Ultra-120 and Arctic Cooling Accelero S1.
