- 3 Jan 2007
- Scotland
I used 4x1GB = 4GB Corsair Dominator DDR2-800mhz C4 with Corsair Airflow - pretty good run on my gaming - no problem at all
. i'm not sure if its worth it or not with 32bit if i get a graphcis card with 2x512mb of memory. Suppose its only £35 lolI understand your point or your skepticism. However, it really would not make sense if Corsair employees wrote articles about mice, HDs, or other products we DON'T make.So, a RAM manufacturer conducts a series of tests that proves that you need more RAM! It may well be true, but I'd rather the test was done by someone independent like Anand or Tom's.
Check the info out for yourself.
Don't see what all this Vista 2gb is cack, stuff is all about.Vista runs fine for me with 2gb... although I hardly use it as I can't install the gfx driversDon't see what all this Vista 2gb is cack, stuff is all about.
Would obviously like as much ram as possible to stop HDD caching though which at the end of it, is as much as you need.
Matthew
That graph insults my (and everyone else's) intelligence. When I do move to Vista64 and 4gig ram, it will certainly not be made by Corsair![]()
LOL!! welcome to the muppet show, who cares if you buy corsair ram, ocz ram, crucial ram, g.skill ram etc just because you dont believe the results?That graph insults my (and everyone else's) intelligence. When I do move to Vista64 and 4gig ram, it will certainly not be made by Corsair![]()
I did not notice anywhere it says anyone will be forced to change to Vista 64 or forced to use any specific brand.That graph insults my (and everyone else's) intelligence. When I do move to Vista64 and 4gig ram, it will certainly not be made by Corsair![]()
It actually isn't, it makes no sense. If the minimum framerate on crysis is higher with 4GB and the average framerate is the same, it means the maximum must have been lower with 4GB which clearly isnt right.
