Just installed my 4870 and the catalyst control centre and noticed that the gpu temp is at 80 deg
Is this normal? Is there any way in CCC that I can bump the fan speed up or anything?
Nope, it's seriously not happening. Got it on 95% now and it's dropped by 2 deg!
Seriously not getting on with this card. I thought it was going to waz all over my 8800GT, but the performance is actually worse, so it's going back - will probably get a 9800 GX2 or GTX280...
No way a 4870 card is worst then a 8800gt you have some issues somewhere.
Yep does work,,make sure overdrive is enabled and on my card I had to change the automatic setting to manual in the XML profile file,remember to activate your profile after.
Somethings definately wrong there. The profiles do work, as again Im using it with the hotfix drivers. Performance wise something is definately wrong, as the 4870 wazzed over my 8800*GTS 512* the improved version of your card, by about 30% on average. I'd take a look at your system in general.
I've got my fan on 35% (from stock 22) and idle temp has dropped to just shy of 50, so something is definately wrong with either your system or your card.
PS. Have you tried uninstalling the drivers, cleaning off everything and just using the hotfix drivers?
A driver issuse would be the biggest culprit. Nothing wrong with my system, even did a clean istall of everything recently. Can you send me a link to where you got your hotfix from?
Anyone got this working for both cards in crossfire as i can only successfully manualy control the fanspeed of one card ?
