Easy's Q9250 Testing
Caporegime
24 Dec 2005
Autonomy
Has a Vid of 1.2v and a 7x multi.
So far so good.
I will be happy with 500 FSB:)
have these been released fully? or did you thieve it from somewhere?
what's your mobo and temperatures?
No they haven't been released yet.
The mobo I am using is a P5Q Deluxe and I can't get a Temp program to work. :(
The only one that I can get to work is PC Probe, but that gives me the bios reading of the cpu temp.
Not the individual core temps like you see in core temp.:p
they have 12mb cache, they are cheap (probably cheaper than a Q6600)when released
ive had mine for a couple of months now, working great @ 3.5Ghz (500x7) @ default volts
yeah the early samples didnt have temp sensors, so mine shows as -126 lol
has a nice 1.1875vid though
What mobo are you using maddness?
Also will we be ever be able to read temps?:eek:
same P5Q Deluxe, no i believe our chips dont have the sensors implemented tbh, purely due to being early samples. Retail ones / later samples will for sure
does your asus probe give a reading? as mine just says -126
That sucks :(
What bios version you running?
I'm getting odd behaviour with 803.
When I restart sometimes I get nothing on screen and then I have to clear cmos.
What VTT and PLL are you using for stability at 500MHz? I can boot into Windows at 500MHz, but it's not stable.
