Whos Posting On The Slowest Comp?
I found a BT Internet Welcome pack/cd earlier from ~1998.
Plan 180: 3 hr internet up to 33k for £4.70 + £2.35 per hour after that!
Not a slow pc but it's a semi-related look back into the past :P
Haha I'm tempted to drag an old rig out of the cupboard, I'm sure I've got an oldskool Slot 1 Celeron 300 with 128Mb of RAM that just needs plugging in :p
Was going to say, if I sign in on my PDA, then me with...
201Mhz CPU
64MB Ram
But I can't be bothered to sign in and post using it, the 320x240 screen is bad for OcUK viewing/usage.
InvG
I win, mine is 300mhz\32MB :p It actually crashes after a while on the forums though...
I know mine hates images, I can load about 3 then it cries that it's run out of space...as it has about 3mb free at the best of times...Windows Mobile 6 is great...
InvG
InvG
Pocket IE uses over 30MB ram to load a regular website, hence crashing unless its a mobile-optimised one. The rest of the OS uses a few mb so its just IE that's the problem...
I'm probably not posting on the slowest computer here, but here's my non-internet powerhouse:
With nothing running my memory status is as so...
Storage
Total: 31.44 MB
In Use: 28.94MB
Free: 2.50MB
Program
Total: 47.90 MB
In Use: 36.61 MB
Free: 11.29 MB
It's because it's a low powered PDA Phone rather than a dedicated PDA, so it runs strangely. Still, only had it crash about twice over the past 4 months, my previous Nokia N73 crashed every couple of days.
Anyway, that was kind of off topic. :)
InvG
Probably not the slowest the I had to revert to my 8 year old Toshiba laptop a few months back. I don't even know the specs of it. All I know is it's horribly slow, and has a great burn mark around the centre of the screen of which the origin evades me.
