Do you clean your mobile phone?
19 Dec 2003
UK
Slightly OCD of course... But...
Does anyone here use a baby wipe or similar to clean there mobile phone after a day of use or whenever you think it's needed?
Is there specific non-harmful cleaners you can use?
I say this, whilst typing on a keyboard I very rarely clean, so half OCD I am lol
Yup mine gets wiped with a wet wipe every few days. Mainly cos the screen gets filthy and theres only so many times you can wipe it on your top before it doesnt work any more.
I also hoover my laptop keyboard if that helps your OCD worries as well.
It's probably perfectly safe to use wet wipe, but in the past i've really gone overboard and the soap from the wipe has got between the keys and messed the phone up.
I guess the trick is just gently do it and not to squeeze the wipe!
Put my w880i in the washer about a year back. Had a nokia N95 8gb since then. :)
LMAO!!!
Aye, I use screen wipes on my Vario II. Other than that, it gets a quick zap with good auld Mr.Sheen every once in a while.
I'm guilty of not using the case I got with it, so it certainly does get grubby kicking around during daily use.
