UK Map of Cellphone Towers
Status
Not open for further replies.
This was me when I was 4000+ metres away from a tower
I've been about 100 metres away from one for the past 5 years and I am ok, don't you think?
I was just wondering if you can buy wallpaper that will block radio, stuff that creates a faraday cage for your room?
That might be something Magick would like to have, you'll need to do the floor, ceiling, door and windows to make it work though, you should be able to get some clear film for the windows and some conductive paint to fill in any small areas you need.
yeah it's called chicken wire. and you don;t need it completely enclosed you can have quite big holes, eg a car will act as a Faraday cage despite the windows.
Although he wouldn;t be able to listen to the radio or use his mobile but presumably he doesn't anyway because of the dangers of such.
Status
