If you decide you want to update your computer manually rather than reinstall - Do the following
got the device manager. Choose the + sign next to the Computer device.
Right click on the Advanced Configuration And Power Interface (ACPI) PC, and choose Update driver.
Then Choose "Not at this time" when being asked to check Windows Update.
Click "Next"
Then Choose "Install from a list or Specific Location (advanced)
Click "Next"
Then Choose "Don't Search. I will choose the driver to install"
Click "Next"
In the next list choose the top option, which should be "ACPI Multiprocessor PC"
Click "Next"
Follow the instructions that popup (you might need a windowsXP CD/DVD) and this will install your system as a Multiprocessor system.
NOTE: Only try this on ONE system and make sure you dont have any Data which you are currently using for any projects your on - as although this wont damage your data, if the process has issues you might not be able to get to the desktop after you change the configuration. This is unlikely to happen but just in case
Hope you have some luck with either of the solutions
Cheers
ROfu
Click "Next"
Click "Next"
Click "Next"
Click "Next"
Cheers
ROfu
