What mouse for long hours using CS3?
6 Jan 2006
Notts/Derby
Hi all
My wife is a wedding photographer and uses CS3 for most of the post processing. This sometimes involves long hours at the PC using the mouse.
This is starting to have a negative effect as she sometimes (more often than not) gets painful areas in her hand and wrist. She currently uses a Microsft Wireless mouse (2 button) where the buttons are not exactly a 'soft' touch' and I suspect that due to the amount of clicking the left mouse button this could be the source of the issue.
Does anyone have any experience with mice that have less travel on the button or is a softer action? Or any recommendations please?
Has she thought about ergonomic mice? There are quite a few options available inculding some which are upright so your hand is at 90 deg to the usual or perhaps using a graphics pen and tablet.
The best thing to do would be to try out a few options and see which is most comfortable for her as what works for someone else may not work for her.
The main thing with a mouse is to get the right size mouse. The mouse should be big enough that the hand rests on top of it and isn't grasping the side all claw like.
Beyond that, the wrist and lower arm should be parallel to the desk, so there is no contact and the upper arm is being used to move the mouse (never the wrist)
The wrist is full of nerves so if it is contact with anything (wrist rest) for a long time you can get pinched nerves at pressure points.
(Had an ergonomics assessment there lately)
I use one of these at work http://www.contourdesign.com/perfit.htm
They are expensive as hell, but incredibly comfortable if you get on in the right size.
These are also apparently very good http://solutions.3m.com/wps/portal/3M/en_US/ergonomics/home/products/ergonomicmouse/
You can twist your wrist to move them, so you dont stress your wrist but i never got used to one. Again, expensive.
Since your talking photoshop and lots of clicking a graphic tablet might be the way to go though.
I'm afraid I don't know that and even if I did I probably couldn't mention as they'd be a competitor, I'd suggest a quick internet search to see if there are any ergonomics practitioners or similar near to you as they might be able to offer advice and/or let you try a few input devices.
Razer Deathadder, super comfy, and the buttons start about halfway up the mouse so they're easy to click
that with a wrist rest :)
Thanks, much appreicated. I have been looking online but agree that its a try before you buy job.
I switched from a Razer Deathadder to an MX Revolution, I take it to work with me and use it at home aswell, I suffer from tendonitis in my right arm so somthing comfortable is a must have for me and the MX has been fantastic, charge lasts around 2 weeks as well.
Just as an aside, switching hands from right to left when mousing helps a lot too. Takes getting used to and slows you down but well worth it.
brakeinup, i was ill a few months ago, and spent all my time on the pc basically, was playing FPS for about 12-14 hours a day with that mouse and a mouse rest (much more frantic than photoshop) had no pains in my wrists
Ok thanks - I will have a look into all of the above options. And a wrist rest!
Thanks all :)
I have the Logitech MX Reveloution now and its quite comfortable but the G5 I had before it was more comfortable and stopped all hand, finger & wrist aches :)
