Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Hmm i am going to be honest.
I dont like the effect on one at all. Its just to overexposed, maybe if the walls on each side where cropped out it might do the trick.
Also number two seems a little soft to me?
And 4 the dress is far to overexposed, well at least on my screen it seems to be.
Number 4 should be easy to fix if you have the RAW images, or was this effect you were going for.
hmm the first one is overexposed in my opinion, and yeah deffently number 4 would be better without the chair.
nice pics tho![]()
The first one is done on purpose, it's not overexposed (the people in it are fine), the walls and ceiling is pure white, after applying the action is what you get. I like it like that anyway, it frames the people and what they are doing within it.
and the lack of details in the "door frame" is because it isn't a door frame, its a hole through the wall into another room.
niceTough audience this !
you asked for comments!
and i stand by what i said they are over exposed, you can see none of the detail in her dress, it mights as well have been a white bed sheet
