Can't partition under Vista
14 Jan 2004
Reading, UK
Hi all, having a strange problem with what is basically a new PC running Vista Ultimate...The built in disk manager won't let me shrink the partition on the primary disk (incidentally the ONLY disk/partition) to accommodate a second one and I can't for the life of me see why.
This worked fine on my other rig which is also running Vista Ultimate.
Anyone able to shed some light?
how much space is it using up?
what i do..
disable system restore
run cclenaer (to remove temp files)
do a defrag
use gparted live cd to partition
CCleaner and defrag just been done and system restore doesn't pose a problem when partitioning the other PC so I don't think it could be that. Yeah ok I could probably use that CD to do the partitioning but there's a reason it isn't working under Windows and I'd like to get to the bottom of why. Thanks though :D
I had the same problem trying to shrink my partition through Vista. I "would" allow me to do it but only by a few meg. Disabling System Restore allowed me to shrink it by a large amount but still not what I wanted.
Never got it resolved and gave up.
Disable system restore, disable the page file, disable hibernation (powercfg -h off) and try again.
Ok, did all of this and it gave up around 50 gig of the drive in question for me to play with (it's 160 overall I think).
New problem: It claims there isn't enough space on the drive to complete the operation...this clearly isnt true, I think I'm using about a third of it at the most and I only wanted a partition of 15Gb (I tried 10 as well just for the sake of argument).
Any more ideas?
Looks like I may have to, I'm just the type to like to solve a problem rather than work around it...just what I'm like!
i'd've taken the advice of someone sooner than 12 hours after they kept suggesting it.
I meant no offense, like I said, I was looking for a fix rather than a workaround- I'm just that type of person...if something's wrong I like to know why.
