What do you think of this choice of components.
22 May 2007
UK
Q6600 @ 3.4ghz (hopefully)
Akasa Ak-965 Cooler
8GB PC2-6400 RAM
ASUS P5Q Pro
Xpertvision 8800GT 512MB
Hitachi Deskstar PK500 500GB SATA
Optiac 20X DVD+-RW SATA
Corsair 520W HX PSU
Antec 900 Ultimate Gamers Case
Cost £ 560 inc VAT & Del from a competitor(s) and a popular auction site.
Isn't the latter a named competitor too? :rolleyes:
Looks good- really need 8GB RAM though?
It's hit and miss on good Q6600 overclockers at the moment too. Yesterday I had one chip with a VID of 1.18v and from the same batch one with a VID of 1.32v.
I`ve got one from a popular auction site which has been run @ 3.4ghz on air so it should be quite good... could still have a high vid but if its been run at 3.4ghz then it should be ok for what I want. I know there are some really bad ones about which don't go higher then 3ghz.
You could get a ATi 4850 and it would be faster than the GT. Also do you really need 8gigs?, i have 4gigs with vista x64 and i dont even use all of that and i even do video editing.
Apart from that, looks like a nice build .
You could get a ATi 4850 and it would be faster than the GT. Also do you really need 8gigs?, i have 4gigs with visra x64 and i dont even use all of that and i even do video editing.
I will be using Vista 64bit, I had 4gb in my old system and fancied a bit more this time, I got the 8800GT for £ 60 its the best bang for buck you can get.
For £60 its a good buy. All sounds OK - you're probably gonna need to raise your NB voltage slightly to get the 8GB stable.
8Gb of ram is overkill , i have 4Gb and have never seen system using more than 3Gb , bit of a waste of money like everyone is saying :confused:
not if the guy wants to run a few VM's and is a high end Photoshop user etc etc
btw just about anyone i know who went from 4gb -> 8gb in Vista doesn't want to return to 4gb.
