- 22 Dec 2006
- Around Town
Hi there Vista permision turn off how?
Do you mean UAC (User account control), the dialog boxes that pop up when trying to install or change things? If so, don't disable it, if the prompts really annoy you, TweakUAC is your friend, will stop the prompts but leave the other benefits of UAC in place.
[url]http://www.tweak-uac.com/home/[/url]
I'd still leave it on though, it's a valuable security feature that shouldn't interfere too much unless you're using badly written programs (which isn't MS's fault)
like the idea of that, is it safe to use? anyone had any issues with it?
