It is to do with a comedy 'mishearing' and multiple meaning of words as with many puns - take the classic "a man walks into a bar - you think he'd have seen it coming".
i love that one!! lol
So, suppose you're on a game show, and you're given the choice of three doors: Behind one door is a car; behind the others, goats. You pick a door, say No. 1, and the host, who knows what's behind the doors, opens another door, say No. 3, which has a goat. He then says to you, "Do you want to pick door No. 2?" Is it to your advantage to switch your choice?
but you need lift (air going under the wings at speed) to make the plane rise
because the plane is on the treadmill, there is no force what so ever on the wings
1.. so the plane is on the treadmill, at full thrust (and no air is being pushed under the wings)
2.. the pilot now sets the flaps to go from - to the / position, and since there's no air to push against the flaps, it cannot possibly rise into the air
the pilot could do anything with the wings / flaps, and the plane would just carry on at full thrust, not moving at all
Why is there no thrust under the wings?
The treadmill has no effect on air in this equation and the wheels have no effect on the speed of the place, the plane is NOT driven by its wheels.
You've seen the explanation as posted by growse and Anim yet you are still questioning this? The wheels and the treadmill are essentially irrelevant to the question, the plane will move forwards, the wheels will just spin twice as fast in the opposite direction so unless you have something holding the plane in position (a harness for instance) it will move forwards, it will take off and it is as simple as that.
^ Wrongthe plane is not moving, correct? yes.
No, because the conveyor belt/treadmill/whatever doesn't stop the plane from moving. The wheels on the plane provide no power, they are just to allow it to move. If it was done with a car, then it would move nowhere, as the engine directly turns the wheels. But with the plane, the engines push it forwards, but the wheels spin freely. So it doesn't matter what surface the wheels are on, if its moving, etc, the engines will still push the plane forwards, causing the air to move over/under the wings, allowing it to take off.
therefore, the plane cannot have any effects of lift, correct? yes!
-edit, hang on, i'm drawing what i'm saying
