Spec me a soundcard which fits this mobo
8 Jul 2006
Hi i have the
Gigabyte GA-X48-DQ6 Intel X48
http://www.overclockers.co.uk/showproduct.php?prodid=MB-113-GI
with 2x http://www.overclockers.co.uk/showproduct.php?prodid=GX-090-PC
and would like to know what good soundcard i should buy for gaming which will fit this motherboard with the 2x Ati 4870's installed. I have been looking at the
Creative Sound Blaster X-Fi Xtreme Gamer Fatal1ty Professional Series 7.1 Sound Card - Retail, but dont know if it will fit with crossfire cards installed on that motherboard.
You should be able to fit a X-Fi pci card on the very bottom slot or you could fit one of the new pci-e ones in the lower pci-e x1 slot.
If going for the standard pci one then just get the Extreme Gamer. No point in shelling out another £30 for a fatality branded one.
