- 25 Oct 2002
- Cambridge,York,Bristol
i was about to get one done when the car broke down on the way there
[TW]Fox;12118350 said:Ok so we all know this bunch are offering unfeasibly cheap oil changes at the moment. Just quoted £33 to change the oil in my car with Castrol Edge 0w30. Have decided it's worth getting it changed - although the OBC is telling me I don't need a service for another year I just dont like the idea of oil being in the car for 2 years, and I've only done 5k since the last service a year ago.
So, that said, has anyone actually done the National oil change deal? How did it go? Were they reasonably competent?
Are they going to trash my car, or fill it with 10 litres of mineral oil, or cockup in other as yet unimaginable ways or is at all very pleasant and easy?
[TW]Fox;12118586 said:I explained what oil it is in the first post - it's Castrol Edge 0w30. I've no idea why its expensive, it just is. Car takes 6.5 litres but the smallest practical amount you can buy yourself is 8 litres @ £40ish a can.
I've told the story on here before. They spilled oil on my hot manifold and I got home to an engine fire.
Why do you need that specific oil if you don't mind my asking?
2 years will be fine. I appreciate that you may feel better changing it now though. The USA is currently having a big education roll out from all the oil companies to try an get them to change there oil less often. Out there 3,000 mile changes are still normal. Even though longer drain intervals will mean less oil sold, the enviromental benefit of less used engine oil to dipose of far outweighs it.
IMO they wont be using the specific recommended oil for your engine
I have seen and cant believe a lot of americans menatlity on this. Both on the Audi and BMW forums some of the guys insist as soon as their oil looses the honey colour and gets a bit dirty on changing it. They wont listen to anyone else in their eyes its now dirty and knackered.
[TW]Fox;12119354 said:The Americans seem to be utterely obsessive about preventative rather than reactive maintainenance even when it's far from appropropriate. Over on the Yank forums it's absolutely essential, apparently, to change the entire cooling system (Radiator, Expansion tank, pump, thermostat and all pipework) every 60k. And most of them actually DO do this...
The majority of dealer filters we have had at work are aftermarket filters rebranded, iirc the last Honda filters we ordered in were Champion filters, vauxhall use Fram filters etc.I have always heard its best to stay clear of third party filters as well, which they will definatly use. I would happily use a mann filter or whatever on an old car but not on something i care about.
i heard that that cost is only for like 5 litres, so will cost more for what you need?
