Used one of those spinny drain unlockers (only has a small hook, not a auger) on both and still blocked. Luckily doing it on the toilet didn't bring back up half rotten poo and toilet paperany solutions, call out plumbers?
Best trick is to get a mop. Force it into the bottom of the bowl. Push it in and out and the blockage will often clear. If there is an issue further down the system you may have no joy though.
Either get a plumber, or spend 20 quid on some drain rods from wickes or similar and give that a whirl![]()
Drain rods are better really,
You had the manhole cover up outside? is that filling with water?
if you decide the DIY drainrod route, make sure you twist it clockwise at all times every time you extend the rod.. if you go anticlockwise they will unscrew and you will lose the rod down the drain, and in turn, pay a hefty fee to get it out lol
or the mop could break and you have to stick your hand down and get it, which happened to me![]()
How do you open the drain cover?
