PS2 to USB converter, compatible with XBOX360?
6 Sep 2007
Rather than buy a new USB keyboard, would a PS2 to USB converter suffice (have loads around work) plugged into the 360?
Anyone here using a converter with success?
I thought the 360 didn't support keyboards?
EDIT: Did alittle research, ps2 - usb keyboard will work fine. Only use for a keyboard with the 360 is sending messages though, I think.
Yeah that should work, its only useful for messaging/typing in games. You can't use it as a control method. Id recommend the messenger kit, brilliant little accessory.
Cheers, I know that I can only use a keyboard for chat and what not. But the thing is, I *know* it should work, however I was hoping someone had first hand experience with a Ps/2 to USB converter.
Thanks for the input.
