Top Gear Returns Sunday 22nd June 2008
he really broke it? he could have died.. right?
I very much doubt it. If he had broken his neck, at the very least he'd be in one of those big support collars for weeks and that would have been noticed.
My guess is that strain+hyperbole = broken.
A human head masses about 5Kg. So hooning around like that would have made his head weigh about 65N sideways, with sudden loading and unloading of the weight as he cornered. That's quite a strain on neck muscles.
Copied from PH:
:p
lmao :p
Some breasts!!! :eek::eek:
On the strength of that I looked some up on google, and I saw bare uncovered breasts where you can see the actual nipples!! ACTUAL NIPPLES!! NIPPLES!!!!!
If you heard the interview that James May did on the radio (it was posted here a few days ago), then he explained it. It's a joke that you only get to see if you are in the studio audience ;)
That image from last night was the guy inserting his member into the exhaust of a Range Rover pic. they did a panned out shot and you could just make it out.
I'm very jelous Fett :(
Don't be chief. I'm buying new, so I'm the idiot. Like Flukester said, give it a couple of years and you'll be able to have your own. By that time, there should be plenty of CF bonnets about, so you won't have to worry about a fully colour coded car either :D
They do the race proper, filming with on-board camera's and a chase car, then they spend the rest of the day going back and filming exterior shots.
This is why there sometimes isn't a rag in tow, and the car is sometimes clean.
Poor continuity, though I suppose it doesn't really matter in this case.
