- 5 Aug 2006
- Derbyshire
As title, I bought an antec300, got it home and ordered a p12v cable extender and a 24pin atx extender as psu cables were not long enough.
Anyway, fans spin, with graphics card on max.....nothing shows on screen. Have tried my brothers 480w tagen and have tried the motherboard out the case on the box it came in with just ram,cpu,gfx and ram, and the same happens (with the psu next to it to see if there were any shorts inside the case and to see if the extender cables were faulty).
I know finding the issue is a matter of trying different parts until the problem is solved, but this will be a problem as I do not have a spare core2duo motherboard nor a spare core2duo cpu.
If I unplug the 12v atx cable (the square 4pin one that is completely different to the 24pin atx), the same thing happens, fans spin and no post.
Any ideas? Thanks
Any ideas? Thanks
