I could be wrong but I think the pads you are talking about are for raising the heatsink up so that it doesn't crush the GPU core. You'd use them if the core is higher than the PCB surround.
Aaaaah spacers. They'll be there to stop you tightening down the heatsink too tightly and crushing the chip.
Which elements will they be covering? SMP capacitors and resistors?
