Need team OCUK help re:Jeans
5 May 2008
Evening, and before you all shout it, yes I've tried google I'm just clearly a noob at it.
What I'm after, 42" waist jeans that are tapered or slim fit. Closest I can find is burtons doing a 40" which I can get into but want a bit of baggy.
Worst comes to worst I'll just order some custom made ones but means having to wait.
Realise slim fit on fat person doesn't really make sense but fat people jeans seem to think that if you got a big waist then your legs must be like tree trunks :s
Meant to add, dont mind if I have to order them from america or something.
ANY help is appreciated.
Cheers.
because most are. im currently in 42" jeans (which are baggy around the waist, could get away with a 40 easily) yet i find most jeans are too small around the thighs - mine are currently 31" ish.
are you telling me that you are a 42" waist but have small legs? bet that looks a bit odd?
try tescos :]
though why burtons dont fit you i dont know, anything other than baggy/loose in there is far far too tight for me!
S'ok, cheers anyway shifty. No it's just with all my 42 jeans I have like elephants arse cos theres so much loose and baggy jean left over, even on a low rise straight leg. So thats why I thought with a size bigger slim/tapered fit there might not be so much bagginess.
If that makes sense :S
And high and mighty = lots n lots of baggy stuff all over the shop.
