- Remove default symptom
- Evolve airborne
- Put 1/1/1/2 into resistances (putting more into resistances seemingly does very little)
- Pray it reaches them
Putting moisture resistance to 2 lets you infect the water supply.
Well I've tried putting points into all transmissions and putting 3/3/3/3 into resistances and the outcome is the same (spreads every where very quickly except Madagascar). It's silly. Simply luck and a tiny bit of strategy to get Madagascar.
The idea is not to put much into resistances until Madagascar is infected. High resistances triggers responses from governments. You want low resistances + no symptoms until you've got everyone infected.
I know and that still doesn't work most of the time.
Edit: Just played it through twice and not once did a ship go into Madagascar's port before they closed it![]()
Sounds like a fun, addictive game!
