- 4 Apr 2006
- Norwich
Hi all
i have never water cooled before and know very little about it (will be researching before i actually start buying)
my current set up is in sig but i will be looking to buy a quad core cpu and the aim will be to cool the cpu and gfx card.
im aiming to also buy a new case, i wanted a quiet case and one that was supposed to be good for water cooling, the one i am interested is this one
http://www.overclockers.co.uk/showproduct.php?prodid=CA-144-CM&tool=3
the only thing is, does having a case with no window defeat the object of a watercooled set up?
also is it a bad idea as i wouldnt be able to see if there were any leaks or problems?
basically can i have some opinions on the above case.
also any basic hints on watercooling, i have quickly read thru the water cooling guide and will do so again in more detail.
thanks Loki
thanks Loki
