right now i have an Antec 900, pile of crap, anyway, looking to upgrade near christmas time, thinking of the Collermaster Cosmos 'S' Sport, any opinions on it, and anything i need to know, thinking of watercooling
Very good case, and as you are looking at xmas time i'd imagine you would get the revised model (magnets rather than push pins on the front door, new side panel (accomodates tall hs fans), new side fan with grill).
Ive had it since the week it launched and have not had much bother with it, cooling is very good with room for 2 intake 120's, a 200m and 4 120 extractor fans.
Coolermaster support is another thing entirely though...
Unfortunatly the support is terrible, in fact id go out on a limb and say its probably the worst if had from such a large company, take a look on the CM boards, you dont have to go far to find unhappy people...
I dont WC but people ive spoken too who do wc have said its very very good.
The tuniq wont fit with the sidefan attached (thats where my moans about the support came from), but you can take the 200mm sidefan off (the side fan issue will be resolved with the first revision)
the case comes with the 4 in 3 module so it takes 4 hdd's, you could buy another 4 in 3 module from the CM part store if you needed it though.
