removing stock cd player from clio
Just need to pop some rods/those stereo removal hook things, into the 2 round holes either side of the head unit and it slides out.
I had a 2001 and now have a 2008 clio......two small screw drivers inone side at a time
get one side out the go to the other side (making sure not to let the other side drop back) and presto it comes out.... when you put the screw driver in there is resistance, just push past it and it'll loosen out..
you say you dont have the holes ?? is it the tuner list cd radio...???
bullit
ah got it, my brother's friend came round who has a clio and popped it out in 2 secs with a couple of screw drivers :D cheers anyway. also had to remove the light from glove box so i could wire my ipod in
