Tailored vs Slim fit shirts ?
20 Nov 2006
Would someone mind explaining the difference for me. Ive got a wedding on Saturday and im just about to buy a shirt, but dont know which one to opt for.
Thanks.
Slim all the way. I'm "blessed" with a rather large neck for my size so "normal" shirts are always on the baggy side.
Note - Don't get slim if you're fat...
Wheres the best place to buy them online, NEXT states its gunna take 4 - 7 working days for delivery which i dont trust will be here in time for the weekend.
Thanks.
Thanks.
There are next's everywhere. go find one ;]
Next shops are generally open late, and you can get on the way home from work or somat? I often get work stuff from Next in the evenings.
Mind you, your location does not help, your nearly 30 miles from the nearest next!
Tailored would suggest, to me, that you go to a decent shop, get measured and then have the shirt tailored to fit you. Which is the kind I always get.
eek 30 miles! thats some distance :/
order online and hope it comes, can always send it back if not.
if there isnt a next then what other shops are there? im guessing not many?
Tailored shirts seem to "flare out" at the bottom, where as skinny fit will stay skinny all the way down.
I might just take a trip to next in Carmarthen, yes its 30 miles but i need to have it sorted for the weekend. That way i guess i can try them on too.
