i've tried looking, can't find it (whey Q)
Permabanned
17 Nov 2007
Chester/ Bristol uni
What volume is a tub for 5lb of impact whey? It's £1 more for the tub over getting it in a bag, and I could easily get hold of a 1 litre tub from work for free. Would that be big enough?
How much (in grams) of this product does this scoop hold?
It's the large scoop on myprotein.co.uk and the whey is impacy (unflavoured).
i've tried looking on the page of both to find out. the scoop says look on the product page, and the product page says nothing.
Just use the tub from work, and if it is not big enough then store the rest in a sealed bag until you have used some???
Just pay £1 and get the tub, next time you can buy the bag and refill the tub. The powder can be sensitive to moisture and can soak up taste from other things so you want to store it properly.
And I couldn't tell you the exact volume, but 5lb's is more than 1 litre, my tub looks to be more like 10 litres!
