Is Frostytech a reliable source of information?
Only heard about them the last month or two?
Because the later Thermalrights such as the True and the IFX-14 have more concaved bases than the ones that came before and frostytech at one point refused to benchmark Thermalrights based on this problem but on contacting Thermalright they denied that it was a Quality Control problem and at one point made out that the bases not being flat was a design feature so Frostytech held a poll and asked the readers if they wanted Thermalright heatsinks to still be benchmarked even though they got different results from each heatsink in a batch of the shelf due to the bases not being flat.
The results of the poll was that the readers still wanted Thermalright heatsinks to be benchmarked which Frostytech now includes but they will only give off the shelf results and not lapped results in which the True when lapped beats the TR-120.
As I said before, they used different Fans for each.
However, here's an interesting Article for you all to read: http://www.xbitlabs.com/articles/coolers/display/thermalright-si128se-ultra120a.html
The fans are chosen based on the heatsinks Fin Pitch and Heatsink depth for air pressure.
But in anycase how would using the same fan on every Thermalright make the base any flatter ?
Yip the black version is a bit pricier than the standard version, but im going with an all black theme in my eclipse 62 as far as cables and fans. may go for a pair of scythe s-flex.Scythe S-Flex, Sharkoon Silent Eagle, Noctua, Akasa Amber
etc etc
If you have gone with the black version (pricey ouch!), get two fans and make use of the 2nd set of fan grips![]()
