- 4 Jan 2004
- ¯\_(ツ)_/¯
Here's my setup:
Nothing special, 120.3 with 'loons, pump and Fuzion. The fans run around 600rpm most of the time, but they are temp. controlled by the motherboard.
Motherboard is Gigabyte P35 DS4.
Now I've left it on for a while, and all the copper bits for NB, SB and Fets get pretty toasty, so I was wondering if I need a fan over them shifting some air?
Now, how can I fit a fan amoungst all this? Perhaps have a 60mm one benith the Fuzion? Suggestions needed please...
The manual doesn't mention if they need active cooling or not, perhaps once I get speedfan installed it will show me my NB temps? What are acceptable temps for the NB?
The 120.3 is on the top, you can just about see it if you crank the brightness up.... The 'loons below the rad suck air out the case (thru the rad). These are the only 3 fans (so far apart from the PSU fan) is this rig (so far).
