Core 2 Duo E8600 hits 6.25GHz with liquid nitrogen
Permabanned
19 Jun 2007
InURmama
Remember THG did 5.1GHZ on a E8500 recently ?.
QUOTED :
" Core 2 Duo E8600 hits 6.25GHz with liquid nitrogen "
" If we're to believe the latest whispers from rumor sites, Intel will add a Core 2 Duo E8600 to its range of processors on August 10. Supposedly, the chip will cost $266 and feature a pair of 45nm Penryn cores clocked at 3.33GHz. Notorious Taiwanese overclocker Coolaler grabbed an E8600 ahead of the launch, and he's been able to push it a tad higher than that.
Going by the screenshots in the associated Coolaler.com news post, the overclocker's Core 2 Duo E8600 engineering sample successfully hit a staggering 6.25GHz—almost twice its stock clock speed. Achieving that phenomenal overclock involved a combination of liquid nitrogen, a 1.936V core voltage, and a DFI LanParty UT P35-T2R motherboard with its front-side bus cranked up to 625.4MHz (that's an "effective" 2501MHz, considering the quad-pumped nature of Intel's front-side bus).
When paired with 4GB of 1251MHz DDR2 memory, Coolaler apparently completed a 19-iteration Super PI 1M run in just under 7.3 seconds. Impressive, to say the least, although liquid nitrogen isn't exactly an everyday PC cooling solution. "
http://www.techreport.com/discussions.x/15235
You won't gain anything by switching, GPU is the bottleneck long before 3.7Ghz.
Except in games like Sup Com and FS9/FSX where the CPU is the bottleneck?
IMO you should crank everything to the max as when you *do* need it, you have it.
4.5Ghz C2D > 3.6Ghz C2Q in everything apart from Sup Com IIRC.
Not at all. You only see a difference in a couple of strategy games (World in Conflict is one) and then it's only a couple of FPS, unless you're using a low resolution.
