the stock speed of the E8500 is the maximum that would to compatible with my RAM anyway?
)The DS3 should take wolfdales shouldn't it? What rev is it?
I'll hold out for a while longer I think!
Well as he's got the rev1 then it won't work, but if he had the rev 3.3 then he would have a chip that should clock higher, run cooler and use less power if he got a wolfdale.what gains will he see?
Like everyone has said there is no NEED to upgrade.
But who cares about need, u WANT to upgrade.
£150 for at least 4Ghz.
Go for it, its only money!
Is that speculation chomper-of-pasties or confirmed?Nehalem will be out in October and bring with it a new socket. Best to wait until then for a big upgrade.
I think it depends how you define "Worth"Worth upgrading to wolfdale?
VTR, just to put a thought out there may I suggest you upgrade your mobo to a new INTEL® P45 express chipset?
I've used one for maybe a week or two and am finding it very good, would set you up nicely for any further chip upgrades and would perhaps work a bit of magic with your E6300. I reckon you may have nearly maxed that chip but an P45 mobo would either get you a few more MHz maybe or allow the same clock but with less voltage.
