1/2 to 8/10mm connector?
Which block? 1/2" thread sounds really odd.
Unless you mean a 1/2" barb rather than the thread.
its an old asetek block i picked up on ebay
Still don't know if you're talking about thread or barb. If it's 1/2" barbs, then if they can't be unscrewed you can buy reducers that will help connect smaller tubing to them.
If they are 1/2" barbs (ie bigger than your tubing) then just warm up the tubes and stretch them over the barb - gives a great seal!
It'll take a damn site more than warm water to get 8mm tubing over 1/2" barbs.
I'm pretty sure that Asetek never did 1/2" thread barbs.
8/10" tubing? You mean OD?
It sounds like you are confused with ID/OD, and barb thread sizes
This is the kit i bought, the GPU block is on the right, the holes with thread in the actual block i belive to be 1/2 inch diameter, my tubing is 8/10 if that makes sense?
Yeah the connectors at 8/10mm push fittings. Will they not screw into the block?
What size are the one's with blue? If the 8/10 connectors screw into the block then you can use them ok.
Ah there's two different sets of ones with blue bits.
Tbh I would just buy a new set of 8/10mm barbs.
