Massive v Droop
Permabanned
22 Mar 2008
Redditch
images on the left are from prime running and the image on the right is @ idle.
voltage in Bios is 1.5V but under load dropsto 1.39,how can i fix this?
Who cares? Just increase the BIOS voltage until the load voltage keeps you running. I have an Asus P5NE (Nforce 650i) and it's famous for its VDroop and it affects me not in the slightest.
Vdroop is actually a requirement of Intel CPU specifications.
Yeah that is a bit extreme.
And as for just upping volts, it means you'll be running massive volts at idle just to get the load volts you require.
"a requirement of Intel CPU specifications"
Can you clarify if that's vDrop or vDroop your talking about? (or both?)
In MiNxYyY's example:
1.500vCore - BIOS Set
1.456vCore - Window Idle (vDrop, nothing can be done about this as far as I know? edit: apart from pencil mod thanks gurusan)
1.392vCore - Window Load (vDroop, almost gone now we have features like Voltage-Dampener/Load-Line Callibration).
Thats nothing compaired to mine (Before the pencil mod) :
Set to 1.5 in BIOS
- 1.344 (Windows Idle)
- 1.312 (Windows Load)
Asus P5K lol :p
Hey MiNxYyY,
as you can some of the veterans that posted replies don't care much for this subject although I like you have been perplexed by this for many years . . .
I have now got what I would consider a decent PSU (Corsair HX620W) and a decent motherboard (Asus P5Q-Dlx) and using this combo with an advanced feature from the boards BIOS (Loadline Calibration) I no longer encounter any vDroop . . .
I just done a quick test to illustrate my point, although it's an undervolted dual-core so the rules may be different! :o
0.9500vCore - BIOS Set (shows as 0.9280vCore in BIOS health Menu)
0.9280vCore - Windows Idle
0.9280vCore - Window Load (Orthos Small FFTs)
Bye bye vDroop, you will not be missed! :cool:
forgot to add the C onto mine :/
mine is the Gigabyte P35C-DS3R
nope - not as far as i am aware - i have the same board and did a fair amount of research into that pencil mod and it doesn't work with the P35C- DS3R as far as i could find. Shame cause it's a great board apart from the v droop
And did it let you overclock further?
Actually, on the P5N-E 650i board, it does allow you to overclock harder in day-to-day usage where you want to allow the system to idle and then come up to 100% rapidly. The stock board has such massive vDroop that it just falls over at the biggest voltage available (1.6V) so being able to remove the droop means you can clock harder than before. It also makes the idel temperatures look sane again (not that that is important).
