For all tattoo lovers/haters. come discuss.
26 Dec 2004
Sweatshop.
Right then,
recently in the papers i read about cream, Now dont go jumping to conclusions thinking im talking about the rip-off cream you rub into the skin to fade the tattoo, im not.
Im talking about a cream which is tattooed/injected under the skin and breaks the ink under the skin and forms a blackscab on the surface which you look after and takecare of, and after it heals and falls off, it takes the ink with it?
it was quite a believable story and i thought this could be a real method, it was pricey and it had just started over in the US.
So what do we think?
And has anybody any decent links?
-Neoni.
Who the hell are you to tell people what to do with their own bodies? If someone wants to get ink then that's their choice and no ****** elses!
I was under the impression that the cream was for when people decided that they didn't want the "ink" anymore.
You also need to calm down a tad.
I believe it was an opinion, which at a guess is actually OK in a tattoo thread for once (going by the title).
lol, their just uptight cuz they got one too many of their male partners names tattoo'd across the glutes, on second thoughts this cream sounds ace!
Hope you ain't being serious a bit overboard seeing as the OP was about getting tattoos removed. Was a good point made, that you should think about it before doing so as it may be with you the rest of your life. Jeez.
I wouldn't mind getting one removed from my arm that is to small tbh (tattoo to small not arm:D)
Then I could have a sleeve designed and wouldnt have to compromise the design.
