On saturday I mixed this band - http://www.disturbinthepeace.co.uk/hotterthanhell.htm with my Mackie system and it was superb.
Even 2 proper sound guys in the audience commented how good the sound was.
Their only criticism is they don't like the thought of amps built into speakers.
how much we talking for the bins?
But they'll make your bass drum sound superb.
http://cgi.ebay.co.uk/Mackie-active...272274259QQcmdZViewItem?hash=item180272274259
http://cgi.ebay.co.uk/Mackie-SWA-15...270152277QQcmdZViewItem?hash=item260270152277
Peaveys, frigging massive things i seriously cant think of the model numbers im googling![]()
Are they active or passive?
Something you could do is just buy just one SWA1501 bass bin and slave the Peaveys off it.
You could put it centre stage and you'll be surprised what one bass bin will do.
You would come out of the mixer into the SWA1501 and because of its crossover you would then lead out to the Peaveys amp.
Hehe, to me this is like someone saying "spec me a PC" and nothing more!Any decent bass bins anybody knows of i dont want anything too stupidly priced tbh!
Passive or active!
-Neoni
Ok, what price do you want to pay? Are they for PA use, car use or indoor use? Size of room?
SPL requirements? Freq range requirements?
PA gives high SPL, but limited extension, it usually rolls off below 40Hz but this isn't always the case especially with larger cabs.
Home subs tend to give plenty of low-end extension below 40Hz, but don't offer the SPL that PA subs do.
Three things. Loud. Low. Small. Pick two. I chose loud and low and now have a 6'2" tall horn.![]()
Regardless, I'd probably go for some sort of horn-sub, they are big but worth it.
Ahh, if you are using a bass also then you'll need good output down to 40Hz, 41Hz is the lowest fundamental frequency on a bass (I think)... The only things below 40Hz tend to be either synth sounds or those huge kettle drums that orchestras use...
If you want it to sound good outdoors then you'll need around twice the speakers as you don't have a ceiling for the sound to bounce off...
Right, this is megabucks but look at it anyway:
http://www.htfr.com/more-info/MR206461
Dual 18" loaded bass bin. It will also need a £300-£500 amp to supply the power to drive it to it's full potential.
Now, this beats it (look at the SPL graph), and can be built for less than £200, and you don't need a massive amp to drive it either as it's more efficient:
http://www.billfitzmaurice.com/Tuba36.html
When I say built, I mean you have to cut and glue some plywood. Now, if you or a friend can do this then awesome... Do it. If not, there is a guy in the UK who is a registered builder who sells pre-made cabs. Get 2 or 4 and you'll have silly amounts of bass!
I've built some of these cabs and they do what they say on the tin... They beat many commercial cabs for a fraction of the price.
If you don't like the idea of non-branded cabs, just google/ebay the well known makes (JBL/Mackie), and avoid the less well known ones.
