Hi all, I've recently decided to re-install FSX & FS9 after a complete re-format & re-install of Windows.
Everything games wise is running fine (Such as battlefield 2, GTR2 etc) with the exception of FS9 & FSX!
In a nutshell, in either simulator, when I'm on the runway, things run smoothly, I can switch to outside view & pan around no problem with an average of around 15fps in FSX & near 40fps in FS9
The moment I start to move i.e. apply throttle, the sim drops to an fps rate of 0.5 and jutters along like a slideshow.
If I slew into mid air, or, persist with the stutters until I can take off (not a mean feat!) the sim returns to normal & runs fine & smooth.
The reverse happens on landing,Everythings fine until my wheels touch the ground and then everything stutters along @ 0.5fps!
As I say, its in both FSX & FS9 that this happens!
Any ideas?
FSX is updated as is FS9
My specs (as i think its probably hardware related)
AsRock 4CoreDUAL SATA2 Mobo
E2180 CPU @ 2.0Ghz
AGP Ati X1950Pro 512MB
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel DDR2
Cheers.
Any ideas?
E2180 CPU @ 2.0Ghz
Cheers.
