Are suspension bolts different in terms of strength to normal bolts?
I have to drive to leicester first thing tomorrow and today set about changing my lower wishbone, unfortunatly the nuts that were welded onto the wishbone were made of cheap alloy and wouldn't torque up fully (pattern parts
). I went to 3 different spares places and none of them stocked a suitable nut as the bolts have an odd thread pitch.
In the end I bought some standard threaded m10 bolts and matching nylock nuts and replaced 2 of the existing bolts. However I recalled previously trying to buy a nut to go with one of these bolts and being told that they were high tensile, will the bolts I have bought be suitable replacements (off the shelf from Halfords)?
