duron did sound like a brand of contraceptive tbh
That's a bad thing?
That's a bad thing?![]()
I think it's i786 as opposed to the original pentium pro's i686. Y'know, for the i7 part. It'd make sense since the shift to QPI from the old FSB is quite a big change (that and Netburst was P68, not i786. >>).
hurrah - first post to have no sarcastic comments or silly logo alterations![]()
I was very tempted to post one that said 'hard core', but thought that was a bit lame.![]()
Thats also true...hmm.
AMD should have stuck with Athlon\Duron, they sound much better than "Phenom".
Except that Phenom means "outstanding or unusual thing"
Will the Nehalem require new motherboards, cause if it does i wont bother getting a new motherboard just yet?
Yepo.
Phenom doesnt mean anything, but Phenomenal does indeed mean extraordinary / remarkable. I rather think AMD's ego was rather large at the time, considering the Phenom doesnt really do anything that Core Duo cant already do. Its not a bad chip, but it certainly isnt extraordinary.
Yep only gives you decent performance for short periodslol
does that one cost extra as you need a medic to power it up?
