vista start up error
2 Aug 2006
Liverpool
hi when i logon to vista i get these 2 error messages, vista wont continue loading up any other start up items until i click ok on both, is there anyway to fix this
Disable the adobe manager starting on boot using msconfig? All it does it auto update adobe products iirc, can still do it manually when you want to.
OK.
Run regedit and check these to places. Make sure your either admin or regedit is 'run as admin'.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
Should show startup progs.
Or, use this. A more powerful msconfig basically.
OK.
nothing to do with adobe in any of them
