http://www.overclockers.co.uk/showproduct.php?prodid=SW-045-MS
is this the upgrade or the full version seems tobe very cheap
Well £190 with the VAT.
As the advert doesn't mention Retail Upgrade then you can safely assume it is the Full Version (if not then you'll be demanding a refund I'm sure!).
Ultimate is quite probably more than you need, however for £190 you have a copy of the OS that is goof doe the life of Vista.
No matter how many times you upgrade your PC, change your PC you'll be able to transfer this license from machine to machine.
OEM Ultimate would set you back £90 and that's good for only one motherboard, so this is a bargain.
While it says its the Upgrade, I have never been able to upgrade any Version of Windows at all, and I have only been able to install a fresh install onto a new HD!!!???
The issue with upgrade is that if you are upgrading from an OEM version of Windows, the minute you buy a new motherboard your upgrade version is now unlicensed until you buy a new license from which you can upgrade. Upgrade is only worthwhile if you've bought a full retail version of Windows at some point in the past, as far as I can see.> The Upgrade version is fully retail anyway
> The Upgrade covers any previous version of Windows
> The Upgrade covers any previous version of Windows.
However, the Ultimate version is absolute crap and I think that the Premium is the best solution
Did you ever run the installer from the DVD within an existing copy of Windows while it was running? It's the only way you can actually upgrade.... stick the DVD in a boot from it and the only option you'll get is a new install.
Not true. The upgrade path is 2000 or XP.
Yes, you are correct and I do know that, but anyone running anything before that, will not be on a PC that is capable of running Vista anyway, so I assumed that would be at least obvious.
And please before you go quoting me, Im not saying that a PC running Windows 98 is incapable of running Vista, Im only talking in general.
I see what you are saying, but then, XP OEM will also turn the Upgrade licence into a VISTA OEM licence. ( and they can also go back too. )
The Vista upgrade can upgrade ANY version of 2K or XP whether RETAIL or OEM, so, Windows 98 does not even come into it in this case does it?
I think we are both accepting that going from 98 to Vista is not a normal thing to do!
So, no... It wont even upgrade using an upgrade disk...
The only options I get ( And these are at different times ) are to install on a clean HD or alongside current O/S but never has it given me an option to upgrade...NEVER!
