Best budget P45 board?
Caporegime
9 May 2004
Leafy outskirts of London
I saw the MSI Neo-F P45, and thought it looked like a logical chipset move for me.
I assumed it would perform on par to my Neo-FR, but give me proper crossfire options in the future for my 4850, but I can't find any reviews, and the onboard cooling isn't as good as my P35.
So my question is, which <£90 board gives the best bang for buck?
Would be pairing it with an E7200, with hopes of hitting 3.5Ghz+
Did the price just shoot up £8?
Grrrrr!
What are the differences between the P5Q and P5Q Pro?
well apart from the price £11.75 currantly i believe, the only other differnce is the number and type of expansion slots each board has.
P5Q
- 1 x PCIe 2.0 x16
- 2 x PCIe x1
- 3 x PCI
P5Q pro
- 2 x PCIe 2.0 x16, support ATI CrossFireX™ technology dual at x 8 speed(blue)
- 3 x PCIe x1
- 2 x PCI
The only other difference I can see is that the plain P5Q has some yucky looking wing heatsinks whereas the Pro has the snazzier ones. :)
p5q-pro
Surely X-fire option alone is worth an extra tenner - not to mention the better heatsinks - the only reason I could see for buying the p5q is if you were dead set on DDR3 as it supports it an DDR2 but the p5q-pro doesn't
(according to the descriptions onsite anyway).
P5q-pro for the win! - Hope to get mine next week (just need to decide which CPU - do I make my wife happy and spend £112 on a 3Ghz Wolfdale or do I make myself happy and broke and go for an e8600 e0 stepping 3.3ghz beast)
I was looking at running the board with:
OCZ 2GB (2x1GB) PC2-9200C5 1150MHz Reaper HPC Edition Dual Channel DDR2 (OCZ2RPR11502GK)
1150MHz RAM Speed, CAS 5-5-5-18 Timings, 2.3-2.4v VDIMM, Lifetime Warranty with OCZ.
OCZ 10+ in stock £51.99
(£61.09)
Are there any known incompatabilities with this memory and the board (seems like a bargain at the mo)
62 quid for 2gb is anything but a bargain. Go for the 4gb of OCZ PC2-8500 Platinum for the same price.
(£61.09)
I got my ocz stuff for £33 delivered
You will not find a better budget board than the Biostar Tpower I45,
that is if you can find it.;)
I have managed to, at a very good price as well, is it really all that?
One review gives it a 7/10, another 9/10, so I guess a 8/10 aggregate aint bad :)
I have to hold out for Payday though, hehe
I believe so.
I will also give it 9/10, as nothing in this world is perfect.
I don't think you will be disappointed if you were to purchase it, especially at the price I have seen it at.
I paid over £50 more and I am still pleased with my purchase.
I don't think i'll be importing again, but at the time I ordered, I couldn't find it anywhere in the uk and it didn't look to be anywhere on the horizon.
I have had it installed in my pc for over a 6 weeks now and it has only just started appearing.
