If you gamed at 1920 x 1200 all max what GPU would you get?
26 Feb 2007
Blackpool
as the thread says, if you gamed at the res. with all settings highest etc...
Specs:
Q6600 @ 3.0ghz
XFX nVidia 790i Ultra mobo
4 x 1GB DDR3
2 x Raptors RAID 0
1100w PSU.
which graphics card would you get??? i have an ULTRA but its great but not that good at 1920 x 1200 as i want it.
What card do you already have? 8800 Ultra? - I'd see if you can source a second one cheap/second hand and SLI them as you have an SLI board.
4870X2 seems to be the best "single" card for that res at the moment - but its a huge amount to spend when you can get almost as good performance with another ultra in SLI if you can find one cheap.
Along with an A/C unit to combat the heat from them, the PSU and mobo :P
I game maxxed out at 1920 x 1200 with a pair of 8800GTX OC2s - As Rroff says a second Ultra should be more than enough and relatively cheap :)
1x 280GTX
1x 4870X2
SLi 280GTX
Tbh
Would that be the 1 x 280GTX before the 1 x 4870X2 Chimerical? I have a very similar spec to the OP and game @ the same res and I am looking to upgrade (my psu is a Seasonic S12 600W). Thanks and sorry for the thread hijack :) Oh and my mobo doesn't support SLI.
4850 would give you playable framerates - but you'd see games dropping to 30-40fps in places with everything maxed out.
I'd say 4870 is the minimum ATI card to comfortably play at that res.
I'd say the 1x 280GTX is a better choice than the 4870X2 for the OP, seeing as he could SLi it later and 1x 280GTX can be bought for £258 compared to £375 for a 4870X2.
yeah but i'm getting an antec fusion case .. i dont know if the card will fit ... and as for the gaming ....i'm hardly cutting edge on that department .. still playing Wolf et ... will be using my upgraded pc as mostly moves / hi-fi tbh
X2 even beats 280 SLI :eek:
For anyone whose interested.
