what voltages with the Asus P45 Deluxe?
Permabanned
22 Mar 2008
Redditch
Got it all up and running today C2Q Q6600,4850,4 x 1GB PC6400 800MHz C4.(Disabled Express gate as pile of rubbish).
After checking with Coretemp i have a VID of 1.3V :(:(:( same as my old P35.
Gone straight into BIOS and done 333 x 9 on Vcore but set all other voltages to there lowest settings,Memory running @ 864(close to that).
Now when it comes to stress testing with Orthos,It only stress tests 2 Cores out of 4 :/
Also,what is the best BIOS for the Deluxe?
Thanks
With Orthos you may need to run to instances and select the cores you want it to test, if not try Prime 95.
Sorry can't help regards which BIOS to use.
Thanks
set your CPU PLL, FSB TERMINATION AND NB voltages to +0.02v as the board overvolts a lot on auto or first manual setting, and use prime95 to stress a quad core cpu, bios 0803 is meant to be good. id also suggest dropping your memory voltage by 0.08v (eg if your ram is rated at 2.1v knock it down to 2.02 for 2.1 true) again this is due to the board overvolting to much.
Currently running the latest official bios, 1103. No issues that I've noticed so far.
I'm currently testing a Q6600 with Prime95 as mentioned above, and it stresses all four cores.
