17" alloys on a Mk1 Focus
Thanks :) , just the fogs and lower grill.
Really? That simple? Well, it certainly look the part.
If you do some searching on the web, you can get the eibach springs for £100.
Is there a particular model number he should be looking for?
Oh, and I completely forgot to ask about how much it should be lowered - or are the Eibach springs all the same drop?
I've only seen them at 30mm for the focus so far, the 1.4/1.6 are different to the 1.8/2.0 springs, so make sure he's careful that he buys the right ones :D . They are usually narrowed down by engine size, hatch/saloon.
Ben.
I wouldn't go for lowering springs alone having done it myself on a previous car... get some shocks, too.
Defiantly good advice, but depending on the budget it isn't that bad. But you will wear the shocks out much quicker by doing so.
I don't like them, talking 45 profile. 40 If you want it to sit a bit lower, but 45 will be fine.
Eibach springs on a budget, wouldn't even consider anything else.
Pretty much what he said, I just prefer the slightly lower look though :)
I would try and get some Eibach Shocks as well if you can but you wont have any issues with just the springs.
