Weekend Special Deals & Other Great Offers - BUY NOW!!
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
Some great special deals here for you for over the weekend period until Monday midday:-
Asus Rampage Extreme Intel X48 (Socket 775) PCI-Express DDR3 Motherboard
Catering to the extreme needs of overclocking enthusiasts, ASUS has unveiled the new ROG Rampage Extreme motherboard. Backed by world-renowned ASUS engineering, this cutting-edge hardware utilizes a full set of features to provide users with varied overclocking options. Through the ASUS Extreme Engine, overclockers will enjoy high performance and stability for ultimate overclocking; while TweakIt provides total overclocking control options. To maintain temperatures at an optimum, the ROG Fusion Block System provides exceedingly efficient heat dissipation through a hybrid thermal design - keeping Northbridge temperatures 22.7% cooler. The ROG Extreme Engine is a next-generation dynamic multi-phase power management system. Equipped with high performance ML Caps (Multilayer type Polymer Capacitor) located at the CPU, Memory and Northbridge, this special power design ensures a stable power supply during overvoltage by lowering ESR (Equivalent Series Resistance) - resulting in reliable performance the mission-critical components of the processor, system memory and the Northbridge. These premium ML Caps integrate seamlessly with the True 16-phase power design that incorporates 3-phases for the Northbridge and 2-phases for memory - ensuring power stability to allow users the peace of mind to venture into high voltage options in the BIOS. The Extreme Engine is also able to achieve a high power efficiency of 96% - resulting in less energy loss and less heat production. Additionally, settings can be changed on-the-fly to yield even greater heat dissipation. Undoubtedly, by combining a next-generation multi-phase power design with additional overclocking headroom, the ROG Extreme Engine redefines the ultimate enthusiast user experience. The ROG Rampage Extreme also includes an optional thermal kit for even better heat dissipation! With a removable MOS heatsink, NB heatsink and optional fan, users can mix and match cooling options to meet every cooling requirement. This customizable cooling option works on the back of the existing ASUS exclusive Fusion Block System - the most versatile, efficient, and advanced on-board thermal system in the world. Combining the ROG's award-winning heatpipe design with a factory-installed chipset water block, this revolutionary hybrid cooling system provides exceptional thermal improvement to the Northbridge, Southbridge, and even VRM components on the motherboard. While connected to a water cooling system, this hybrid cooling system simultaneously dissipates heat from chipsets and VRMs to provide cooler temperatures for added stability. TweakIt is a brand new feature that caters to users who want a convenient way to perform trial and error runs for overclocking without entering the BIOS for great time savings. With the joystick-like control, every overclocking option is available for the user - allowing them to utilize performance optimizations "on-the-fly"! Used in conjunction with the LCD Poster device, gamers can then overclock during gaming for that competitive edge - bringing about a brand new dimension to overclocking and benchmarking.
- Pentium 4/Pentium D/PentiumEE/Core™2 Duo/Core™2 Quad/Core™2 EE/45nm CPU LGA775
- Intel X48 with ICH9R
- 1600/1333/1066/800 FSB
- 4 x DDR3 2000(O.C.)1800/1600/1333/1066/800/667
- 2 x PCIe 2.0 x16
- CrossFire X16+X16
- SATA 3Gb/s*6(RAID 0, 1, 5, 10)
- 2 x 1394a
- SupremeFX II Audio Card
- 2 x Gb Marvell PCIe
- Heatpipe Design
- Voltiminder LED,
- COP EX,
- CPU Level Up,
- Loadline Calibration,
- Extreme Tweaker,
- ASUS EPU,
- LCD Pster,
- Onboard Switch,
- Q-Connector,
- Green ASUS
Price: £204.99+VAT (£240.86 inc VAT)
BUY NOW!
G.Skill 2GB DDR3 HZ PC2-12800C7 1600MHz (2x1GB) CAS7 Dual Channel Kit (F3-12800CL7D-2GBHZ)
G.Skills HZ range is aimed at high-performance computer systems where the memory is often overclocked and stretched to its very limits. This 2GB PC2-12800 memory kit is an excellent choice for overclocking. This kit is rated to operate at 1600MHz at timings of 7-7-7-18 (1.9 volts) and it is an excellent kit for gaming and high-performance memory systems. Designed especially for Intel based systems, such as the Intel X38 and Intel P35 chipsets.
- 2GB (2x1GB)
- 1600MHz CL7-7-7-18 @ 1.9V
- 6 Layer PCB
- 240 pin, Non-ECC, Un-buffered DIMM
- Retail Package
- Lifetime Warranty
Price: £79.99+VAT (£93.99 inc VAT)
BUY NOW!
G.Skill 4GB DDR3 HZ PC2-12800C7 1600MHz (2x2GB) CAS7 Dual Channel Kit (F3-12800CL7D-4GBHZ)
- 4GB (2x2GB)
- 6 Layer PCB
- Retail Package
- Lifetime Warranty
Price: £159.99+VAT (£187.99 inc VAT)
BUY NOW!
Kingston HyperX 4GB (2x2GB) DDR2 PC2-6400C5 800MHz Dual Channel Kit (KHX6400D2K2/4G)
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR. HyperX is available in single and dual-channel memory kits.
- PC6400 800MHz CAS 5-5-5-15
- 240pin, Non-ECC, Un-buffered DDR2 SDRAM DIMM
- Aluminum Heat-spreader
- 6 Layers Ultra Low Noises Shielded PCB
- Lifetime Warranty
- 1.9V-2.1V Power Supply
Price: £43.99+VAT (£51.69 inc VAT)
BUY NOW!
Kingston HyperX 2GB (2x1GB) DDR2 PC2-9200C5 1150MHz Dual Channel Kit (KHX9200D2K2/2G)
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR. HyperX is available in single and dual-channel memory kits. Kingston's KHX9200D2K2/2G is a kit of two 128M x 64-bit 1GB (1024MB) DDR2-1150 CL5 SDRAM (Synchronous DRAM) memory modules, based on sixteen 64M x 8-bit DDR2 FBGA components per module. Total kit capacity is 2GB (2048MB). Each module pair has been tested to run at DDR2-1150MHz at a latency timing of 5-5-5-15 at 2.3 - 2.35V. The SPD is programmed to JEDEC standard latency 800Mhz timing of 5-5-5-15 at 1.8V. Each 240-pin DIMM uses gold contact fingers and requires +1.8V. The electrical and mechanical specifications are as follows:
- PC9200 1150MHz CAS 5-5-5-15
- 64x8 DDR2 BGA Chips
- Lifetime Warranty
- 2.3V-2.4V Power Supply
Price: £32.99+VAT (£38.76 inc VAT)
BUY NOW!
OCZ 4GB (2x2GB) PC2-8500C5 1066MHz Reaper HPC Edition Dual Channel DDR2 (OCZ2RPR10664GK)
The latest PC titles that make use of DirectX 10 crave more than the standard 2GB of RAM for the ultimate gameplay experience and the highest settings. Computer enthusiasts and professionals utilizing high-bandwidth video, music, and graphics applications will also benefit from the ultimate balance of speed and density the new PC2-8500 4GB Reaper HPC offers. To ensure superior stability and performance over the entire life of the memory the Reaper HPC Series makes use of an innovative cooling solution to more effectively dissipate heat produced by high-speed memory. The thermo-conductive copper heat pipe conduit is ideal for overclocking where every degree matters. The new modules also offer instant overclocking right out of the box with EPP (Enhanced Performance Profiles) programmed into the SPD. PC2-8500 Reaper modules will immediately boot at the rated specs on the latest generation of NVIDIA® SLI™ chipsets. EPP eliminates the need for manual configuration and makes the benefits of overclocking available to the complete range of consumers looking to get the most out of their systems. The PC2-8500 Reaper HPC Series will be available in 4GB (2x2048MB) Dual Channel Kits. Although the OCZ Reaper HPC series can meet all enthusiast demands, this high-capacity, high performance memory can become a user-friendly household item for the complete range of consumers looking to maximize system performance with additional RAM. As part of OCZ’s line-up of premium memory, Reaper HPC PC2-8500 modules are backed by a Lifetime Warranty and industry-leading technical support so you can push your high-performance memory to its limit.
- 1066MHz DDR2
- EPP 5-5-5-18 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- OCZ Lifetime Warranty
- 2.1 Volts
- 240 Pin DIMM
- Reaper HPC Heatsink*
- EPP-Ready
- 2.15V EVP**
Price: £64.99+VAT (£76.36 inc VAT)
BUY NOW!
Gainward GeForce GTX 260 896MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
Get pulled deeper into the gaming experience than ever before with next generation NVIDIA GeForce GTX 260 GPU. GeForce GTX 260 make games including Unreal Tournament 3, Assassin’s Creed, Call of Duty 4: Modern Warfare and S.T.A.L.K.E.R.: Clear Sky – feel like the real thing. High definition worlds crackle and hum with cinema-quality clarity. Lifelike characters behave with such realistic intensity that your palms sweat and your heart races. Objects react to the forces of nature exactly as nature intended. And with 50% better performance than previous generation graphics processors, you get it all...No lag. No dropped frames. No compromises. Beyond the field of play, the GeForce GTX 260 GPU seamlessly shifts intense processing tasks from the CPU to the GPU. Dive into the latest Blu-ray movie, run the Folding@home protein folding application to help cure diseases, browse your favorite web sites in 3D with PicLens, or transcode video to a personal video player up to 7X faster than the CPU.
- Bus Type: PCI Express 2.0 (Backwards compatible with PCI Express)
- Memory: 896MB GDDR3
- Core Clock: 576MHz
- Shader Clock: 1242MHz
- Memory Data Rate: 1998MHz
- Processor Cores: 192
- Shader Model: 4.0
- Texture Fill Rate: 36.9 Billion/sec.
- Memory Interface: 448-bit
- Memory Bandwidth: 111.9GB/sec.
- API Support: Microsoft DirectX 10 and lower, OpenGL 2.1 and lower for Microsoft Windows
- Display Connectors: 2 Dual-Link DVI-I, HDTV + TV Out
- RAMDACs: Dual 400MHz
- HDCP Capable
- HDMI Capable
- 2-Way & 3-Way NVIDIA SLi Support
- Card Dimensions: 266.7mm x 95.3mm x 38.1mm
- Warranty: 2 Year
Price: £141.99+VAT (£166.84 inc VAT)
BUY NOW!
Leadtek GeForce 8800 GT ZL OC 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Your search for the perfect graphics card is over. The ideal combination of power, performance, and price, the NVIDIA® GeForce® 8800 GT graphics card offers 112 stream processors, a 512MB 256-bit frame buffer, standard-setting GeForce 8 Series features and, a strikingly immersive DirectX 10 gaming experience. Ultra-realistic smoke, rain, explosions, lighting, terrain deformation and motion blur enable jealousy-inducing, lightning-fast gameplay in the hottest games, including Crysis, Hellgate: London, Call of Duty 4, and Gears of War. With full support for PCI Express 2.0 and featuring second generation NVIDIA PureVideo™ HD engine, the SLI™-Ready NVIDIA GeForce 8800 GT graphics card was worth the wait.
- GeForce 8800 GT core running at 650MHz
- Zalman Heatpipe Silent Cooling Solution
- 20 °C Lower than NV Reference Cooler
- Shader Clock Speed of 1625MHz
- 512MB GDDR3 Memory running at 1800MHz
- 256-Bit Memory Interface
- 112 Stream Processors
- Shader Model 4.0
- Memory Bandwidth: 57.6GB/s
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- 2yr Warranty with OcUK/Leadtek
Price: £72.99+VAT (£85.76 inc VAT)
BUY NOW!
EVGA GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (768-P2-E831-AR)
The EVGA 8800 series is the world's first DirectX 10 graphics card with full Shader Model 4.0 support. It delivers unparalleled levels of graphics realism and film-quality effects. Even more, it also supports the NVIDIA Lumenex™ engine to give unsurpassed image quality, floating point accuracy, and fast frame rates. Built for Windows Vista™, the 8800 series ensures the best possible performance when running the Windows Vista 3D graphical user interface. The 8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the WinFast® PX8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported. The 8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported.
- GeForce 8800 GTX core running at 575MHz
- Shader Clock Speed of 1350MHz
- 768MB GDDR3 Memory running at 1800MHz
- 384-Bit Memory Interface
- 128 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 36.8 billion/sec
- Memory Bandwidth: 86.4GB/s
- HDCP Enabled!!
- 10 Year Warranty Direct with EVGA on 0049 8918904911 (TOLL FREE)
- 90 Day Step-up/upgrade programme from day of purchase (Upgrade your card and only pay the difference direct with EVGA)
- 24/7 Email Support at [email protected]
- All RMA's & Upgrades are dealt with between EVGA Direct and the Consumer on 0049 8918904911
Note: This card is 275mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
Price: £117.99+VAT (£138.64 inc VAT)
BUY NOW!
OcUK GeForce 8800 GT 512MB GDDR3 HDTV/DVI (PCI-Express) - Retail
- GeForce 8800 GT core running at 600MHz
- Shader Clock Speed of 1500MHz
- Shader Model 4.0
- HDCP Enabled!!
Price: £66.99+VAT (£78.71 inc VAT)
BUY NOW!
XFX GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (PVT80FSHF9)
The 8800 series is the world's first DirectX 10 graphics card with full Shader Model 4.0 support. It delivers unparalleled levels of graphics realism and film-quality effects. Even more, it also supports the NVIDIA Lumenex™ engine to give unsurpassed image quality, floating point accuracy, and fast frame rates. Built for Windows Vista™, the 8800 series ensures the best possible performance when running the Windows Vista 3D graphical user interface. The 8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported.
- Shader Model 4.0
- HDCP Enabled!!
- Supplied with Company of Heroes (DX10 Version) Full PC-Game
- 2yr Warranty with OcUK direct (For XFX warranty contact OcUK for RMA and we will endeavour to resolve your problem within 7 working days)
Price: £104.99+VAT (£123.36 inc VAT)
BUY NOW!
Gainward ATI Radeon HD 3850 Pro 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Gainward’s award winning High-Performance/ Wide-BandwidthTM hardware design powered by ATI’s Radeon® HD 3850 GPU integrating 512MB/256bits high-speed DDR3 memory which offers enhanced, leading-edge performance for the 3D enthusiasts. Supports two monitors simultaneously, enabled by ATI’s Multi-Display Technology for office applications, 3D gaming and professional applications, animation or video editing. It allows end-users to select any combination of display configurations, including a DVI, CRT and HDMI. ATI CatalystTM Software Suite provides a full software solution for supported OS and delivers improved performance, certified stability, unmatched visual quality, innovative and exciting features that enables users to quickly setup and configure the graphics product.
- ATI Radeon HD 3850 GPU @ 668MHz
- 512MB GDDR3 Memory @ 1656MHz
- 320 stream processing units
- 666 million transistors on 55nm fabrication process
- PCI Express 2.0 x16 bus interface
- 256-bit GDDR3 memory interface
- Fully distributed design with 512-bit internal ring bus for memory reads and writes
- Hardware processed 1080p video playback of Blu-ray™ and HD DVDs
- Up to 24x Custom Filter Anti-Aliasing (CFAA) for improved quality
- ATI CrossFireX™ Multi-GPU Technology
- HDMI with 5.1 surround sound audio
- ATI Avivo™ HD Video and Display Platform
- Microsoft® DirectX® 10.1 support
- Shader Model 4.1
- 450Watt or greater power supply with 75 Watt 6-pin PCI Express power connector recommended.
- For ATI CrossfireX: 550 watt power supply or greater with two 6-pin connectors.
- 2 Year Warranty with Gainward/OcUK.
Price: £45.99+VAT (£54.04 inc VAT)
BUY NOW!
Gainward ATI Radeon HD 3870 XT 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Gainward’s award winning High-Performance/ Wide-BandwidthTM hardware design powered by ATI’s Radeon® HD 3870 GPU integrating 512MB/256bits high-speed DDR3 memory which offers enhanced, leading-edge performance for the 3D enthusiasts. Supports two monitors simultaneously, enabled by ATI’s Multi-Display Technology for office applications, 3D gaming and professional applications, animation or video editing. It allows end-users to select any combination of display configurations, including a DVI, CRT and HDMI. ATI CatalystTM Software Suite provides a full software solution for supported OS and delivers improved performance, certified stability, unmatched visual quality, innovative and exciting features that enables users to quickly setup and configure the graphics product.
- ATI Radeon HD 3870 GPU @ 776MHz
- 512MB GDDR3 Memory @ 1900MHz
- 256-bit GDDR4 memory interface
- ATI PowerPlay™
- Shader Model 4.1
- 2 year warranty with Gainward/OcUK.
Price: £59.99+VAT (£70.49 inc VAT)
BUY NOW!
Dell Ultrasharp 3008WFP 30" Widescreen LCD Monitor - Midnight Grey
The Dell UltraSharp 3008WFP is a 30-inch widescreen display that delivers stunning image quality at resolutions of up to 2560x1600. Empowered by an advanced video processor, the 3008WFP possesses video processing capabilities that scales up to 2560x1600 resolution (with a dual-link DVI graphics card) and also allows de-interlacing, noise reduction and other video related features. With TrueColor Technology (117% color gamut) and 3000:1 dynamic contrast ratio, this stylish and functional display gives you the rich, life-like imagery and accurate color representation vital for professional content creation like game development, photo/video editing, multimedia and design. The 117% color gamut can support the Adobe 98 color standard, which is ideal for desktop publishing. Extensive connectivity options including VGA, DVI-D with HDCP, S-Video, Component, Composite and HDMI allow you to hook up to most PCs and electronic devices. Dell UltraSharp 3008WFP is one of the first flat panel monitors to offer DisplayPort connectivity, industry-endorsed technology that allows high-definition content to be displayed on PCs. Get the maximum value your business deserves. See More, Do More with Dell.
- 30" Widescreen
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 16.7 Million Colours
- 3000:1 Contrast Ratio
- 8ms Response Time (8ms Grey-TO-Grey)
- 370 cd/m2 Brightness
- One DVI-D Input with HDCP support
- One HDMI Input
- One Display Port Input
- One Analogue Input
- One Component, S-Video and Composite Inputs
- Height adjustable stand (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 4 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
- Before purchasing this product make sure you have a compatible graphics card that supports Dual Link DVI / DVI-D such cards are the ATI X1300/X1600/X1800/X1900 series and NVIDIA 7800 series graphics cards.
- This product is not compatible with AGP cards
- Revision A02 Guaranteed!
Price: £799.00+VAT (£938.83 inc VAT)
BUY NOW!
Powercolor ATI Radeon HD 4870 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
The ATI Radeon HD 4800 Series GPUs bring the power of graphics ‘supercomputing’ to gamers, setting a new standard for visual computing. Redefine the way you play and take HD gaming to the extreme with best-in-class performance. The new TeraScale graphics engine delivers an immersive, cinematic gaming experience. Add this GPU to your PC and watch Blu-ray movies and play HD content with incredible visual fidelity. Do it all with break-through efficiency that doesn’t compromise performance.
- ATI Radeon HD 4870 GPU @ 750MHz
- 512MB GDDR5 Memory @ 3600MHz
- 24x custom filter anti-aliasing (CFAA) and high performance anisotropic filtering
- PCI Express 2.0 support
- ATI CrossFireX Multi-GPU Technology
- Microsoft DirectX 10.1 support
- Shader Model 4.1
- ATI Avivo HD video and display technology
- Unified Video Decoder 2 (UVD) for Blu-ray and HD Video
- Built-in HDMI with 5.1 surround sound support
- On-chip HDCP
Price: £144.99+VAT (£170.36 inc VAT)
BUY NOW!
Samsung SM-2253LW Aqua 21.6" Widescreen LCD Monitor - Glossy Black
The SyncMaster SM2253WW from SAMSUNG recognizes your individuality and enables you to express yourself with clarity and confidence. Its unique, soft minimalist style, premium widescreen design and inspirational imaging quality combine to give you a more emotionally satisfying entertainment experience. With a Dynamic Contrast of 8000:1, you can be sure that the images you view are powerful and vivid. Images born with greater depth and intensity, by the intuitive dimming and brightening of the backlight, a wider range of emotional depth and clarity is achieved, allowing you to fully appreciate all multimedia content. Wall and Arm Mount Design
VESA wall-mount compatible design providing maximum functionality and flexibility.
Designed to meet VESA standards to accommodate any environment whether on desk, on the wall or to any position with arm mount.
- Viewable Area: 21.6” Widescreen (1680x1050 Resolution)
- Interface: Analog / Digital
- Response Time: 2ms
- 16.7M Colours
- Contrast Ratio: 8000:1
- Viewing Angle (H/V): 170°/ 160°
- Brightness: 300cd/m2
- Analog and DVI cables supplied
- 3 Years On-Site Warranty with Samsung
BUY NOW!
Powercolor ATI Radeon HD 4870 PCS Extreme 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
- ATI Radeon HD 4870 GPU @ 800MHz
- 512MB GDDR5 Memory @ 3800MHz
- Silent Cooling solution
- Shader Model 4.1
- On-chip HDCP
Price: £154.99+VAT (£182.11 inc VAT)
BUY NOW!
Leadtek GeForce 9800 GX2 1024MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Beautifully designed and engineered for extreme power, the Leadtek NVIDIA® GeForce® 9800 GX2 1GB graphics card is The Console Within - a complete, high definition entertainment and gaming solution for the PC. With NVIDIA HybridPower™ technology and two on-board GPU's, the Leadtek NVIDIA® GeForce® 9800 GX2 is bar-none the fastest graphics card available and up to 50% faster than GeForce® 8800 Ultra. When paired with an additional Leadtek NVIDIA® GeForce® 9800 GX2-based graphics card and an NVIDIA nForce® 7 Series motherboard, this Quad NVIDIA SLI® technology solution creates the most awe-inspiring, screaming fast gaming platform to date. Be blown away by scorching frame rates, true-to-life extreme HD gaming, a picture-perfect HD DVD and Blu-ray Disc® movies with ultra-smooth playback.
- GeForce 9800 GX2 core running at 600MHz
- 1024MB GDDR3 Memory running at 2000MHz
- 512-Bit Memory Interface
- 256 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 76.8 billion/sec
- Memory Bandwidth: 128GB/s
- Up to 50% faster than GeForceR 8800 Ultra
- Display Connectors: 2 Dual-Link DVI-I, HDMIR Out
- HDCP Capable, HDMIR Capable
- HDCP Enabled!!
- SLI ready
- 2yr Warranty with Leadtek/OcUK
Note: This card is 295mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 600W minimum for PSU and 700W+ is recommended. Also make sure your PSU has true 8 pin PCI-Express connector rather than a 6+2 pin connector.
Price: £177.99+VAT (£209.14 inc VAT)
BUY NOW!
Gainward GeForce GTX 280 1024MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
Get pulled deeper into the gaming experience than ever before with next generation NVIDIA GeForce GTX 280 GPU. GeForce GTX 280 make games including Unreal Tournament 3, Assassin’s Creed, Call of Duty 4: Modern Warfare and S.T.A.L.K.E.R.: Clear Sky - feel like the real thing. High definition worlds crackle and hum with cinema-quality clarity. Lifelike characters behave with such realistic intensity that your palms sweat and your heart races. Objects react to the forces of nature exactly as nature intended. And with 50% better performance than previous generation graphics processors, you get it all...No lag. No dropped frames. No compromises. Beyond the field of play, the GeForce GTX 280 GPU seamlessly shifts intense processing tasks from the CPU to the GPU. Dive into the latest Blu-ray movie, run the Folding@home protein folding application to help cure diseases, browse your favorite web sites in 3D with PicLens, or transcode video to a personal video player up to 7X faster than the CPU.
- Memory: 1GB (1024MB) GDDR3
- Core Clock: 602MHz
- Shader Clock: 1296MHz
- Memory Data Rate: 2214MHz
- Processor Cores: 240
- Shader Model: 4.0
- Texture Fill Rate: 49.2 Billion/sec.
- Memory Interface: 512-bit
- Memory Bandwidth: 141.7GB/sec.
- HDCP Capable
- HDMI Capable
- Warranty: 2 Year
Price: £214.99+VAT (£252.61 inc VAT)[/b]
BUY NOW!
Samsung SM-2493HM 24" Widescreen LCD Monitor - Black
With a wider range of depth and expression, the 2493HM/2693HM monitors from Samsung offer you the ability to take a more expansive view of your world. With their phenomenal resolution, response time and image clarity, they push you to the limits of your potential. With Samsung SyncMaster 2493HM/2693HM, it's not hard to imagine. In order to help you create your optimum work environment, we have created a more versatile monitor which allows you to shape the way that you view your world. The height adjustable stand (100mm) with fully flexible tilt and swivel functions allows easy adjustment of the screen. The hidden speakers allow you to enjoy a more inclusive expression of multimedia content. With an ultra high resolution of 1920 x 1200, images are displayed with vivid detail and unsurpassed clarity. This enhanced attention to detail entails that the monitors are ideally suited for CAD-CAM, Graphic design, and Music/Video editing. The smaller pixel pitch ensures that the image is tighter and more comfortable to view. The wider screen offers heightened working efficiency due to its ability to display more information on a single screen. The 16:10 Wide Format offers a greatly increased screen size for you to appreciate, whether you are enjoying movies, games, or working on creative projects. The wide screen is ideal for the viewing ofWindows Vista and web based multi media content. The ultra fast response time of 5ms ensures that even the fastest moving images are displayed with complete clarity. Blurring, ghosting and trace effects are eliminated, meaning that you are free to enjoy the highest quality images imaginable. The Dynamic Contrast ratio of 10,000:1 displays images with rich clarity of detail. Darker areas of the picture become deeper and more intense, and lighter areas become brighter and more vivid, dramatically enhancing the quality of image. With triple input interface options to choose from, you can enjoy enhanced connectivity through your monitor. HDMI, DVI-D, and D-Sub inputs are available, allowing you to enjoy High Definition digital content with HDCP support.
- Viewable Area: 24” Widescreen (1920x1200 Resolution)
- Interface: Analog / Digital / HDMI
- Response Time: 5ms
- 16.7M Colours
- Contrast Ratio: 10,000:1
- Viewing Angle (H/V): 160°/ 160°
- Brightness: 400cd/m2
- Height Adjustable stand with tilt & swivel
Price: £239.99+VAT (£281.99 inc VAT)
BUY NOW!
Dell Ultrasharp 2408WFP 24" Widescreen LCD Monitor - Midnight Grey
The Dell Ultrasharp delivers rich, life-like imagery and accurate color representation to the home and office with TrueColor Technology (110% color gamut)1 and 3000:1 dynamic contrast ratio. Together with a fast response time of 6ms (typical) that helps prevent ghosting and smearing, viewers can enjoy a more satisfying viewing experience when engaging in digital content creation, gaming and HD entertainment. The 2408WFP brings superb image quality to your desktop with stunning resolutions of up to 1920x1200. Offering about 30% increase in content area over a 20 inch display, the 2408WFP gives you more resolution to work in, increasing efficiency and productivity for professional content creation like game development, photo/video editing, multimedia and design. Extensive connectivity options including VGA, DVI-D with HDCP, S-Video, Component, Composite and HDMI allow you to hook up to most PCs and electronic devices. Dell UltraSharp 2408WFP is one of the first flat panel monitors to offer DisplayPort connectivity, industry-endorsed technology that helps reduce complexity and enhance digital quality. Enjoy the Ultrasharp advantage with intuitive built-in features like a height adjustable stand, 4 USB 2.0 ports and a conveniently located 9-in-2 media card reader - small thoughtful details that make life that much easier.
- 1920 x 1200 (WUXGA+) Optimum Resolution
- Supports advanced features like PIP (Picture-in-Picture) and PBP (Picture-By-Picture)
- True Colour Technology (110% Colour Gamut)
- 6ms Response Time
- 400 cd/m2 Brightness
- Anti-glare surface
- Two DVI-D Input w/HDCP Support
- One S-Video Input
- One Composite Input
- One Component Input
- One HDMI Input
- One DisplayPort Input
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
Price: £324.99+VAT (£381.86 inc VAT)
BUY NOW!
Logitech G5 Gaming-Grade Laser Mouse (910-000094)
Tune for game domination. The Logitech G5 Laser Mouse gives you the edge with a 2000 dpi laser engine sending out an astounding 500 USB reports per second* for precision response at blinding speeds. A Logitech exclusive, the G5's 36-gram adjustable weight cartridge gives you thousands of variations on balance and weight—including one that´s perfect for your unique gaming style. Polytetrafluoroethylene (PTFE) gaming feet provide the ultra-smooth glide you want in a gaming-grade mouse, and Logitech´s SetPoint software allows you to customize your mouse with advanced features such as game detection and in-game adjustable sensitivity (including independent x- and y-axis settings).
- Award-winning Logitech® MX™ Laser 2000-dpi Engine
- “On-the-fly” sensitivity adjustment to 2000, 800, and 400-dpi resolution
- Adjustable weight cartridge allowing to adjust the weight of the mouse by upto 36 grams allowing you to get the perfect balance required to make you the ultimate fragger
- 6.4 megapixel/second image processing
- Up to 20 g of acceleration
- Expanded 16-bit data format supports blazing fast moves with pure precision
- Advanced gaming software, exclusive to Gaming-Grade™ mice, for up to five custom sensitivity settings
- Polytetrafluoreothylene Super-slick gaming feet for effortless, precise tracking
- Contoured grip ensures peak performance and comfort—even in the most intense gaming sessions
Price: £26.99+VAT (£31.71inc VAT)
BUY NOW!
Zalman Reserator XT Hybrid Liquid Cooling System - Titanium
The Zalman Reserator XT is a complete external liquid cooling system for your CPU with an extensive feature list including a warning and alarm system, comprehensive visual monitoring display, pure aluminium casing, double ball bearing fan, automatic on/off sync with the PC, and much more. Powerful and convenient cooling at a low noise level.
- High performance ultra quiet water cooling system
- Active/passive hybrid cooling design
- Automatic/manual fan speed control modes
- Coolant flow & low-level warning alarms
- Automatic on/off when PC is switched on/off
- Supports 754/939/940/AM2/LGA775
Price: £189.99+VAT (£212.78inc VAT)
BUY NOW!
OcUK This Week Only Deals - Click Here!!
OcUK will soon be launching a scheme which rewards loyal forum members too, which will save you even more money!!
OcUK is extremely competitive on all the above deals if not the cheapest in the UK and by quite some margin, so get your wallets out!!
