Safe to run below default fan speed?
24 Sep 2005
Stoke
Just wondering if this can cause any problems. Thinking of dropping the stock fan speed on my 8800GTS G80 below the standard 60% with Rivatuner. :)
Just watch the temps - aslong as its under ~80C it shouldn't be a problem at all - although lower idle/load temps will result in the card lasting longer.
It will only be for idle. Have set up a fan profile to increase the speed at certain temperature points for when i'm gaming etc.
The only reason why i want to do this is because the card is idling at 49c which is pretty damn good for the stock cooler lol. :D
