personalised ringtones on the 3G
Garageband?
Clip it under 40 seconds, and use the "Export to iTunes as Ringtone" feature. Done.
Alternatively, look at iToner.. it'll put any track on the phone, and doesn't require jailbreaking.
There is a website that does it for you, then you just drop the file into itunes (drag and drop) and then just sync.
I use the latest garageband its great!
You can also fade in and fade out making it seems much nicer sounding if your half way through a track.
