- 19 Oct 2002
- Shakespeare’s County
There nothing stopping you from getting them from the US though is there? Just a conversion plug once they are here?
Already been covered, the Xbox headset doesn't work too well around your neck![]()
Make voice output to the headphones and just have the mic around your head aswell? I could easily wear both if I wanted.
I know what I'd rather have, personally I use 5.1 speakers but if I had to choose between a "gaming" headset and proper headphones then I know what to go for.
) but before it broke it was still too much hassle to fiddle with stuffAn audio splitter for optical out when using HDMI should have come with your elite. Try taking it back to the shop maybe =/.
) and you wouldn't have it loud enough for the humming noise if you like your ears working as they do now. Only gripe would be the mic mute isnt on the puck but on the main line control box, apparently making sure that is hanging loosely rather than resting on something can help the humming. I didnt really try to kill it off too much last night as I didnt really notice it in a game.
